Rim Offset Questions....
Old Jun 28, 2003 | 10:49 AM
TurboDANDEE's Avatar
Default Rim Offset Questions....
Well i have an 99 civic with the full Type R suspension swap. Im about to buy some Mugen MF10 Bronze 16x7 with a 50 offset. I was wondering if im going to have problems with clearance, im not too familiar with offsets and im getting different answers from people. could someone clarify this for me? would i have rubbing issues with a 50 offset? Has anyone been through this dilema before? any suggestions would be great, thanx
Old Jun 28, 2003 | 11:25 AM
Default Re: Rim Offset Questions.... (TurboDANDEE)
King motorsports advertises +50 offset for ITR's, can someone confirm that these fit with no rubbing, thanx
http://kingmotorsports.com/product.asp?product=40
Old Jun 28, 2003 | 12:33 PM
sivik2nr's Avatar
I would think that they would probably rub. I have 40 ofset wheels on my 99 civic and they are pushed out a lot farther than the stock wheels. 50 might be just enough to rub under hard cornering.
Old Jun 29, 2003 | 10:40 AM
Default Re: Rim Offset Questions.... (sivik2nr)
bump
Old Jul 14, 2003 | 03:23 PM
bretx0r's Avatar
50mm might rub on the inside of the wheel well rather than on the outside. get 45mm or 42mm if u dont want to worry about rubbing with a 7" rim
Old Jul 14, 2003 | 05:06 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">King motorsports advertises +50 offset for ITR's, can someone confirm that these fit with no rubbing, thanx
http://kingmotorsports.com/product.asp?product=40</TD></TR></TABLE>
50 is factory offset for the Type-R wheel because the 5-lug hub is thicker than a normal non type-R (GSR/LS) integra's hub and sticks out 5mm more. Stock offset for GSR/LS and all civic's is 45 offset.
Nonetheless, you should be fine whether you stick w/a 50 or 42-45 offset. 38 offset might cause rubbing issues for you.
Rubbing also depends on how low your car is.
Old Jul 14, 2003 | 06:45 PM
thanx for the info's guys!
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
speedehatch
Sep 29, 2004 12:22 PM
^jefs0ng
Jan 1, 2004 07:17 PM
SantaCruz92Si
Jul 22, 2003 01:36 PM
