Wtf CEL Code 16 Suddenly After hitting vtec Fuel Injector dead????
I hit vtec my car started giving code 16
Took out the battery wire and took out the Fuel tank PLUG AT THE FUEL TANK code went away hit vtec again and stopped at stop light to make U turn to return home it started blinking the code
What can be the problem maybe fuel injector is dead?
Anyone had similar problem like me I drove the car about under 500 miles since swap WITH NO PROBLEMS..
also I cant rev past 3500rpm BECAUSE OF THIS FUCKEN CODE ..
ALSO READ THE DAM THREADS WITH CODE 16 LOOKS LIKE NO ONE GOT THE CODE 16 FIXED FUCKK
Re: Wtf CEL Code 16 Suddenly After hitting vtec Fuel Injector dead???? (bossman032)
I think it is either the Fuel Pump, Fuel Pressure Regulator, PGMFI Main Relay, Bad Wiring, Clogged Fuel Filter, O2 Sensor, ECU faulty, or Vacume Leak.
I am performing these checks, you do the same and let me know via that instant messenger thing. I like how that works, it is easier than trying to rememer all the threads that you are involved with.
bossman032
12-16-2011 11:13 AM
bossman032
07-16-2003 10:47 PM
