bck frm vacation...wiring civic H22
hey guys finishing up my whippy...basically want to know if i can use a 95 civic EX wiring harness to match up to my 95 h22 ....
i have it in a 96ex with a ECU jumper harness switching form OBD2 to OBD1, thanks ALOT!!!
Re: bck frm vacation...wiring civic H22 (Ddogz15)
Nope will not work. You will need to use your EX factory engine harness, adapt it to the h22a, convert the distributor and use the H22A type fuel injector harness plugs.
Use the OBD2a to OBD1 jumper and plug that up into an OBD1 ecu such as the P13 or you can also go with a chipped P28.
5speed4life
05-05-2006 06:11 AM
