B16A (sirII) with soch injectors?
I been running my swap for about 1yrs+ now, its a 95si with a jdm B16A sirII but used my stock single cam injectors from the sohc vtec , i used my stock si wires and harness instead of the jdm one since it made the swap easier ...... the airfuel gauge does not show me running lean but am i hurting in fuel department? i've raced it at the track a few times but havent broken into the 14's yet, could this be because im using my sohc injectors? Are the Ex/Si injectors on the 5th generation civics enuff to feed the B16A motor? I've never had any problems with the xohc injectors in my B16A, but just want some info on this.... thanks
Re: B16A (sirII) with soch injectors? (spooned out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out »</TD></TR><TR><TD CLASS="quote">Are the Ex/Si injectors on the 5th generation civics enuff to feed the B16A motor?</TD></TR></TABLE>
Yes
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out »</TD></TR><TR><TD CLASS="quote">I been running my swap for about 1yrs+ now, its a 95si with a jdm B16A sirII but used my stock single cam injectors from the sohc vtec , i used my stock si wires and harness instead of the jdm one since it made the swap easier ...... the airfuel gauge does not show me running lean but am i hurting in fuel department? i've raced it at the track a few times but havent broken into the 14's yet, could this be because im using my sohc injectors? Are the Ex/Si injectors on the 5th generation civics enuff to feed the B16A motor? I've never had any problems with the xohc injectors in my B16A, but just want some info on this.... thanks</TD></TR></TABLE>
The SOHC Vtec injectors are rated at 240cc's just like the DOHC ones. I have been running them in my built B17 for a while now with no problems. Ran a best of 14.1 @ 99.9mph.
thanks for the reassurance, i wasn't sure what the sohc vtec injectors are rated at never had the chance to find out but thanks for the info's
