b18c1 in 89crx hf HELP PLEASE!!!!!
anybody have problems with their hybrid starting? when i have problems getting it started i will have to mess with the clutch cable and it will start . One it didn't and it would not start so I took the battery done to get tested and it ended up being bas so I replaced it and it worked for a few days and then it started again . It only does it when the car sits for along period of time .
Re: (dotcom)
Check those two tranny wires. If one is cut or sumthin it wont let you satrt the car caus ethere wont be a signal that the clutch is disengaged. You mentioned something about the clutch...
Shawn Bryan
10-08-2017 10:37 AM
91EF_Si
08-25-2010 12:35 PM
daniel990836
05-28-2009 09:57 PM
M-EJ1
12-15-2002 06:24 PM
