starting problems
Old Jun 26, 2003 | 12:31 AM
self_made's Avatar
Default starting problems
car: 92 civic cx
engine: 92 b17
well, the swap was in for liek 3 weeks, everything went fine...today, the car doesnt turn over, we checked the starter, its fine. we checked the battery, thats fine. we checked to see if it was the clutch switch(no voltage at starter w/o pressing clutch, 12.xx voltage when clutch is pressed, thats correct right?) we tried applying direct current to the starter(wire from positive to both starter plugs), still doesnt turn over, anyone have any ideas? we were able to push start it and it ran
Old Jun 26, 2003 | 02:39 AM
J2turbo21's Avatar
Default Re: starting problems (VTECNLUDE)
So your starter works but it wont turn over when you turn the key?If so when you turn the key can you hear the starter?
Old Jun 26, 2003 | 04:44 AM
VTECVillain's Avatar
Ignition switch?
Old Jun 26, 2003 | 09:28 AM
self_made's Avatar
Default Re: starting problems (J2turbo21)
nope, cant hear the starter turn or anything, and bout the ingition switch, wheres it at? how do I check it?
Old Jun 26, 2003 | 09:50 AM
MaxSterling's Avatar
if your starter doesnt turn then how can you say starter is fine?
obvious if you hook up the starter directly to the 12 v battery and it doesnt do ****, your starter is broke.
Old Jun 26, 2003 | 10:06 AM
self_made's Avatar
Default Re: starting problems (RoyFokker)
did you read my first post? I said I took out the starter, placed it on the ground, and connected wires fromt he battery to it and it engaged/spun, thats what they would do at say autozoen to test if its good or not...but in the car it doesnt turn.
Old Jun 26, 2003 | 10:12 AM
Turbogixxer's Avatar
Do you have power going to the S-termial? Do you have power going to main power to the starter?
Old Jul 1, 2003 | 08:36 AM
dotcom's Avatar
i am having the same kind of prob i am getting ready to change the ignition switch
Old Jul 1, 2003 | 09:31 AM
User 5426's Avatar
Default Re: (dotcom)
The exact happened to me but I mistakenly disconnected a wire to the starter solenoid. Plugged it up and it was perfect.
Old Jul 3, 2003 | 10:07 PM
fourthgenhatchB17's Avatar
yep check the ground from tranny to frame...must be a decent sized wire...
sevenfc
11
Sep 25, 2009 07:26 PM
mwdazzo
Apr 16, 2009 06:09 AM
Touge Tuning
May 3, 2006 11:14 AM
slammedtegls
Sep 24, 2004 07:05 AM
DAYUIZ
Jan 20, 2004 03:03 PM
