99-00 b16a2 into 96 EK hatch
i know 96-98 are obd2 but how would you wire in an obd2.5 99-00 b16a2 into a 96 hatch? what extra wiring needs to be done or what harness do you use?
Re: (mtber)
arent the 96 and up civic harnesses all one piece? the 92-95 are interior and engine harness but the 96 goes from the engine straight to the ecu in one piece, correct?
Re: (deviant1)
get a 96-98 EX civic harness.. it has to be modded alittle to fit the SI engine, but it will fit.. as for the ecu, either run a OBDII DEL SOL DOHC vtec ecu (very rare) or a jdm B16a ecu (but make sure it's OBDII) or get a jumper harness and get a rechipped p28 ecu
ThrowSomeDs
11
06-14-2011 08:32 AM
