b18b swap not running well at all, cant hold idle...
Car; 88 crx
motor; 94 b18b/95 intake manifold......
Well it wont hold idle, first thought was the IACV, replaced it, no luck, then My freinds told me that it may be the ignitor, replaced it, no luck. I checked for vacuum leaks, have not found any. all the sensors are wired corectly, i know because i yanked the sensor wire and then checked the code that it threw for each. I allso checked the intake manifold bolts to make sure that they were tight, they are. Any ideas? thanks in advance. I have failed the smog ref 3 times and its getting expensive, oh allso the smog guy said the numbers are really lean, and its failing the NOx levels. thanks
Rob
Rob
Re: (mr_timluu)
I've got the same problem but only at start up...It won't idle right for about 2 min. Then its fine, i've made sure my coolant lines are good and bled...what else could it be.
rjardy
43
07-15-2003 10:01 AM
