HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values?
I have no vtec
i need the proper ohm resistance reading of:
knock sensor
vtec solonoid
oil pressure switch
so i can test whats screwed. all wiring seems proper. all sensors wired.
knock sensor
vtec solonoid
oil pressure switch
Re: HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values? (cstay)
I was curious about this the other day actually, i have handy here the VTEC Solenoid Resistance...
Should be between the one connector and ground (duh) resistance of 14 to 30 ohms. anything different needs some replacing
And this is according to alldata
Freeltec
07-23-2003 05:38 PM
