baromatic sensor code
I have an ls/vtec and i'm getting the baromatic sensor code the sensor is located in the ecu i swaped ecus and still getting the code any suggestions would be aprecciated
The barometric sensor is located on the ECU circuit board. I suppose its possible that you have two bad ECU's I don't know what else would cause that problem. one way to test it would be to swap both ecu's into another car. If they both throw the same code, you have two bum ecu's
if not, its something else but like I said, I really can't think of what would cause that.
I know I wasn't any real help but good luck
Mike
if not, its something else but like I said, I really can't think of what would cause that. I know I wasn't any real help but good luck
Mike
.brad
Feb 26, 2002 03:30 AM
delsol93
Jun 21, 2001 02:54 PM
