Which intake do I use for B18C EK Hatch?
I have a '99 Hatch with b18C. Which cold air intake do I use?
The motor's stock.
I heard that if you use a skunk2/ ITR manifold, you should use the ITR CAI, but if its stock, use the '99-'00 Si.
Any info is appreciated.
The motor's stock.
Re: Which intake do I use for B18C EK Hatch? (ErikDaGenErik)
Go with the type R because it has a 3" diameter and the Si is slightly smaller,maybe around 2.5".With the gsr mani it will sit slight lower i beleive.
Re: Which intake do I use for B18C EK Hatch? (J2turbo21)
ok. i talked to a couple more people and it seems like the si cai is the way to go. so i ordered it from modacar who also said the si intake would help. turns out i have to cut a holt to he fenderwell. also, the rubber connector didn't fit on the gsr tb, i had to cut a piece of the gsr stock intake tubing.
This kinda post comes up a lot. Just use what ever intake is supposed to go with the engine. Have a GSR engine? get a gsr intake. Engine layouts are all most all the same. I have a B18C in my 99 civic and I bought a GSR injen RD one piece intake and it fits perfectly with no modification. I didn't have to cut any holes or make anything fit.
Re: (ErikDaGenErik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ErikDaGenErik »</TD></TR><TR><TD CLASS="quote">do you have a dx?</TD></TR></TABLE>
yes.
yes.
import-tooner
04-16-2009 09:14 PM
bboyoxygen
14
11-12-2004 08:13 AM
djay86
03-20-2002 08:55 PM
