b18b into ek
i've got a longblock b18b motor im planning to swap into my 1996 civic. will i be able to use integra mounts? or do i have to use 99 Si mounts. i've been told that all you need to change is the rear bracket to the rear L bracket from an 99 Si. also would i be able to use my stock wire harness or do i need to modify? please help!
you need the rear tranny mount from a 99-00 si and the driver's side mount bracket from a 99-00 si as well. if the motor is obd2 you can use your stock wiring harness from the civic with a few modifications and it will be overall pretty easy.
read up on http://www.eddiesun.net/~trey/6gen/ if you need more info...
trus01d1er
Nov 5, 2005 11:50 PM
hatchattak
Sep 2, 2003 03:03 AM
