Check engine Light On MPFI swap
Old Jul 5, 2003 | 11:58 AM
BlkslowCRX's Avatar
Default Check engine Light On MPFI swap
I just did a SOHC non vtec MPFI swap into a 90 DxHatchback. Car Runs fine, But starts a little hard. After the car reaches like 3500rpms, or 3/4 throttle Its throws a code. It is throwing a code 4, the crank angle sensor . How do i fix this? Any Ideas maybe some one has had the same problem
Old Jul 5, 2003 | 03:38 PM
eg6ajk's Avatar
Default Re: Check engine Light On MPFI swap (BlkslowCRX)
check your distributor wiring along with the ECU.
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
Old Jul 5, 2003 | 03:48 PM
BlkslowCRX's Avatar
Default Re: Check engine Light On MPFI swap (eg6ajk)
all the wiring is correct,i went over it like 3 times. im not sure about the ecu. I droped the wire to b12 and it hit the power side of the batt would that cause the coumputer to throw that code sayin the sensor is bad?
Old Jul 5, 2003 | 06:38 PM
VTECVillain's Avatar
Did you use shielded wire?
Old Jul 5, 2003 | 06:43 PM
BlkslowCRX's Avatar
Default Re: Check engine Light On MPFI swap (VTECVillain)
all the distruburot wiring is. By the way i saw you have a 90 si computer for sale how much ya want for it?
bad23591
Jun 3, 2014 04:16 PM
DA9Sleeper
Nov 6, 2011 06:57 AM
ZCeddie586
Jun 23, 2011 09:01 PM
jgraphics
Dec 4, 2010 09:39 PM
xvracing
11
Oct 27, 2003 05:21 AM
