B20B/Z into EG
B20B/Z into EG
I have read up a little bit on the crv (aka b20) swap, but I still don't know to much about it. I wanna swap a b20 in a 92 civic hb vx. If I remember correctly I have to change the axles, injectors, distributor, and some other things, but forget what else. If anyone has does this swap I would greatly appreciate any links on how to do the swap and what I need to change, blah blah blah....thanks!!!!
Re: B20B/Z into EG (import92c)
Depending on which motor you got (Orthia or CRV), you'll need to use the bracket that's on the right side, as that is what is needed for an EG chassis. If you use the one on the left, the motor will be sitting way low on the driver side and it'll look weird (friend forgot to swap it and when all mounts were in, it looks funny.... wish I took a picture).
hey im doin the same swap into my 95 but i still dont know all the stuff that i need. Do u think u can list them for me when u find out all the stuff u need. i want to get it done before the hondafest.
Re: B20B/Z into EG (jp300zxtt)
man it was pretty simple swap. you will need to get a 94-00 ls intake manifold,
94-00 wiring harness, distrubtor, exhaust manifold and of course a b series trans, you can use 94-00 ls, gsr engine stock mounts.. use your civic end mounts. rubber ones.. thats what i did..94-up b series axles/shaft.... 94-95 obd I ecu... i kind of mixed obd II and I parts together and it runs fine.. no cels etc..
