obd0 to obd1
Old Jul 10, 2003 | 09:06 PM
ProJectCvic's Avatar
Default obd0 to obd1
hey guys. i was arguring with this one guy today. i told him that in order to put his b18a setup in his obd1 civic he would need to change the ecu, dizzy, injectors in order to work. He says that he would also need to buy and obd0 -obd1 conversion. I was like WHY when you switch the plugs already to match the harness?!?! I have never personally seen a conversion kit that he talked about, but i do not think that it is needed. What do you wiring expert think? Thanks
Old Jul 10, 2003 | 10:56 PM
Turbogixxer's Avatar
Default Re: obd0 to obd1 (ProJectCvic)
You are right about changing stuff. You need a OBD1 -> OBD0 if you use a OBD0 ECU. And he would need to get the right motor mounts too.
Modified by turbogixxer at 3:15 AM 7/11/2003
Old Jul 11, 2003 | 11:40 PM
4crx4me's Avatar
If the car is already OBD1 why not just upgrade the motor to OBD1,
Instead of downgrading the cars wiring to OBD0. Sounds like a backward
step. And alot more work. Then, he wouldn't need the conversion harness. Yes, I think you are correct and he is wrong. Can anyone confirm? katman? blown90hatch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">hey guys. i was arguring with this one guy today. i told him that in order to put his b18a setup in his obd1 civic he would need to change the ecu, dizzy, injectors in order to work. He says that he would also need to buy and obd0 -obd1 conversion. I was like WHY when you switch the plugs already to match the harness?!?! I have never personally seen a conversion kit that he talked about, but i do not think that it is needed. What do you wiring expert think? Thanks </TD></TR></TABLE>
Old Jul 12, 2003 | 09:20 AM
Default Re: obd0 to obd1 (4crx4me)
thanks!!
dr_latino999
236
Mar 28, 2020 12:34 AM
4g4dcruisin
Feb 3, 2010 03:06 PM
projsectEF
Jul 25, 2006 12:32 AM
NewBorn_EG
Nov 6, 2004 02:13 AM
euy
Aug 4, 2004 07:15 PM
