B18c1 in a del sol 94
Curious I have a whole setup from a gsr motor tranni shiftlinkage etc etc .. As for a civic I know all you need is ecu motor mounts and axels. But as for a Del sol what is different and has to be done.? Please list thanks
TSPeed Factory
Re: B18c1 in a del sol 94 (spider69911)
as far as i know nothing has to be done differently. everything that applies to 92-95 civic applies to a del sol too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spider69911 »</TD></TR><TR><TD CLASS="quote">Curious I have a whole setup from a gsr motor tranni shiftlinkage etc etc .. As for a civic I know all you need is ecu motor mounts and axels. But as for a Del sol what is different and has to be done.? Please list thanks</TD></TR></TABLE>
You'll need a del Sol VTEC shift linkage too, the GSR linkage won't fit in a del Sol.
Re: B18c1 in a del sol 94 (b18sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sol »</TD></TR><TR><TD CLASS="quote">
You'll need a del Sol VTEC shift linkage too, the GSR linkage won't fit in a del Sol.</TD></TR></TABLE>
del Sol vtec shift linkage would be needed for any b series swap correct?
Re: B18c1 in a del sol 94 (mooseknuckle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mooseknuckle »</TD></TR><TR><TD CLASS="quote">
del Sol vtec shift linkage would be needed for any b series swap correct?</TD></TR></TABLE>
yup u got it cameltoe
