H22 eg swap - grounds to ecu wire or chassis...
Hey, do I ground the wires from the Intake air bypass and Knock sensor to an ECU pin or anywhere on the chassis? I assume it's fine to ground to the chassis and it shouldn't matter? Thanks.
Re: H22 eg swap - grounds to ecu wire or chassis... (SleeprCivic)
Best thing to do would be to ground it on the ECU (like the TPS ground or something else that's a ground signal), otherwise just ground them where you have a chassis ground near the thermostat housing.
