IAB wiring?
Old Jul 12, 2003 | 12:31 PM
TheKid's Avatar
Default IAB wiring?
96 OBD2 GS-R in 92 Si HB.
Using P72 OBD1 ECU and 96 GS-R Engine Harness.
How do I wire up the IAB butterflies?
Old Jul 12, 2003 | 12:36 PM
00DVPGSR's Avatar
There are two wires from the IAB...it does not matter which is which because it is a solenoid...one goes to the ECU (pinout A17) and the other to a 12V power source.
Note: For an OBD2 ECU one goes to the ECU and the other is a ground wire.
Old Jul 12, 2003 | 12:39 PM
TheKid's Avatar
Default Re: (00DVPGSR)
should i just cut the wires at the solenoid plug and run them to the ecu? or can i get the wires at the shock tower somewhere?
Old Jul 12, 2003 | 12:43 PM
00DVPGSR's Avatar
I cut them at the solenoid, spliced in new wires, ran one to the ECU and one is at the battery for now...we are still in the process of working out getting VTEC working...damn ECU is looking for the oil pressure switch that does not exist on JDM motors.
Old Jul 12, 2003 | 10:13 PM
brian g's Avatar
One small clarification here, OBD2 for 96-98 has one wire to ECU and one to ground. If it is a 99-00 OBD2 GSR ECU , it is the same as the 94-95 Integra.
00DVPGSR, just get a US VTEC solenoid and oil pressure switch and bolt it on.
brian g
Old Jul 16, 2003 | 07:28 AM
SpyderZEX's Avatar
Are you getting a CEL code eventhough the vtec is not wired up all the way? I ask this because I am not getting any codes from the ecu, and I don't think that my vtec is working. I just wanted to see if the ecu would tell you if vtec is not working.
Old Jul 16, 2003 | 08:40 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00DVPGSR &raquo;</TD></TR><TR><TD CLASS="quote">...we are still in the process of working out getting VTEC working...damn ECU is looking for the oil pressure switch that does not exist on JDM motors.</TD></TR></TABLE>
there's an easy fix for this.
Simply cut the VTPS power wire and splice it into the VTEC solenoid wire then ground the other VTPS wire, and VTEC will worky.
Old Jul 16, 2003 | 08:07 PM
crxhybrid1320's Avatar
Default Re: (Katman)
Katman is that information correct on the IAB wiring for the OBD 1 and OBD 2.
OBD 1=Power source
OBD 2=Ground
Do you know of any places to find the ECU wiring for an OBD 1 H22A.
Thanks,
JAson Tamalavicz
Old Jul 23, 2003 | 09:34 AM
00DVPGSR's Avatar
Thanks Katman that is what we ended up doing and the car works now.
Next up is the power stearing...going to try and cap it off and install a breather...maybe on Sunday
Old Jul 23, 2003 | 05:35 PM
Fuster_Cluck's Avatar
Default Re: (TheKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKid &raquo;</TD></TR><TR><TD CLASS="quote">should i just cut the wires at the solenoid plug and run them to the ecu? or can i get the wires at the shock tower somewhere?</TD></TR></TABLE>
You have to cut the black wire at the harness. The OBD2 motor has it going to a ground so if you splice in at the shock tower you'll blow the ECU fuse because there are other grounds tapped in to that wire as well. I did use the wire at the shock tower harness for the pink/blue though. It took forever for me to figure out the IAB wiring. If you need pics I can post some for you. I also have a video that proves the secondaries open when the car is reved past 6k in neutral so you can check that way
Rok_Stok
Oct 21, 2010 01:06 PM
gorthjr
May 11, 2010 08:55 PM
lukehowell88
Nov 11, 2007 01:39 PM
red97EX
Sep 20, 2005 10:42 AM
ozzyman
Sep 4, 2002 07:57 PM
