b20 into ek need help with mount!!!!!!!!!!!!!!!!
Old 07-02-2003, 10:17 PM
fkncivic's Avatar
Default b20 into ek need help with mount!!!!!!!!!!!!!!!!
well i put a b20 into my 98 coupe and we ran into the problem that the old integra ls tranny that i am using doesnt have the holes for the front tranny mount i figured that i could use the mount that hooks up to the ac bracket but it wont line up. so what do i do can i find a different b series ac bracket that will line up if so which one it kinda looks like the ac bracket for a 99-00 si will work but i have no clue. if the ac bracket mount isnt the answer then what do i do???/ please help
Old 07-03-2003, 05:38 AM
Butch's Avatar
Default Re: b20 into ek need help with mount!!!!!!!!!!!!!!!! (fkncivic)
You need the 99-00 SI AC mount. I have one for sale if you need want it.
Old 07-08-2003, 08:38 AM
fkncivic's Avatar
Default Re: b20 into ek need help with mount!!!!!!!!!!!!!!!! (Butch)
i found an article that says i need the part from the b16 del sol. is it the same as the one for the 99-00 si???? and also do i use the stock mount peace that is on the chasis??
Old 07-08-2003, 10:55 AM
AL ASPIRATED's Avatar
Rear 99-00 SI Bracket mount
Front Driver side Lower 99-00 SI AC Mount
Front Lower Tranny Side 99-00 SI Mount
Everything else is from ur civic. do not change anything else but these.
deucedeuceEK
05-01-2016 10:40 PM
CallmeLuke
11-28-2003 10:12 PM
fkncivic
07-02-2003 10:17 AM
jcivic
02-11-2003 07:56 PM
u2civic1
02-06-2003 06:58 PM
Quick Reply: b20 into ek need help with mount!!!!!!!!!!!!!!!!
