Redline/revlimiter only 7200rpm on my itr setup help
Since last week when i got my car out of the shop, i was running the stock cx cluster, with no tachometer. But yesterday, i got my civic si eh3 gauge cluster, and my rpm wasnt working ( https://honda-tech.com/zerothread?id=558456 ) , we figured it that my blue wire from distributor was not in right pin, we had to wire one up. Ok, so with that the redline on my guage cluster is 7200rpm
My car revs to redline, and to maybe 7300rpm, that is like the fuel cut off.
Funny thing is, its like acting in accordance to the redline on my cluster.. What could be the problem?
setup
jdm 96 itr
stock jdm p73
96 gsr / ex hybrid? wiring harness
kenji obd1-2 jumper
I posted this in EG forum, but not enough response, i should i have posted here in the first place
EDIT: Fixed the CEL, was knock sensor..
Video of problem I'm having: right click save as!
http://www.we-todd-did-racing....DE%3D
Modified by Jawad at 6:29 PM 7/11/2003
Modified by Jawad at 6:31 PM 7/11/2003
Modified by Jawad at 6:32 PM 7/11/2003
setup
jdm 96 itr
stock jdm p73
kenji obd1-2 jumper
Re: Redline/revlimiter only 7200rpm on my itr setup help (Jawad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jawad »</TD></TR><TR><TD CLASS="quote">Since last week when i got my car out of the shop, i was running the stock cx harness, with no tachometer. But yesterday, i got my civic si eh3 gauge cluster, and my rpm wasnt working ( https://honda-tech.com/zerothread?id=558456 ) , we figured it that my blue wire from distributor was not in right pin, we had to wire one up. Ok, so with that the redline on my guage cluster is 7200rpm
setup
jdm 96 itr
stock jdm p73
kenji obd1-2 jumper
I posted this in EG forum, but not enough response, i should i have posted here in the first place</TD></TR></TABLE>
ok, i'm confused.
You say you're using a CX engine harness, if i'm not mistaken, then in your list at the bottom there, you say you have a "96 gsr / ex hybrid? wiring harness" ...
are you sure you know which harness is being used on your engine ?
setup
jdm 96 itr
stock jdm p73
kenji obd1-2 jumper
ok, i'm confused.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jawad »</TD></TR><TR><TD CLASS="quote">...Iposted this in EG forum, but not enough response, ...</TD></TR></TABLE>
yea most people in the EG forum, dont know squat and rant about bs they know nothing about. might as well name it appearance and cosmetic forum II.
Jawad.
11-30-2003 09:00 PM
Jawad.
15
07-11-2003 05:16 PM
