b16 or gsr tranny
Re: b16 or gsr tranny (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">which one is better?
it all depends on what kind of driving you do.
Doesn't the b16 have shorter gear and is better?
yes the b16 does have shorter gears which makes drag racing/auto-x phenomenal but not good when your going 80 on the highway at 4500rpm
What is the going price on this tranny?
www.jdmhondaparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">Hydro on both</TD></TR></TABLE>
the gearings are similar regardless hydro or cable.
Re: b16 or gsr tranny (eg6si)
"yes the b16 does have shorter gears which makes drag racing/auto-x phenomenal but not good when your going 80 on the highway at 4500rpm"
wow...4500rpm at 80?
Re: b16 or gsr tranny (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Go gsr tranny, most b16's have bad 3rd gear syncros. </TD></TR></TABLE> so true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">i will go on the highway often..should i go with a gsr tranny then?</TD></TR></TABLE>
a B16 tranny isn't that bad on the freeway in 5th gear. Its up to you.
Re: b16 or gsr tranny (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">B16
or
ITR (if you have the $ for one)... </TD></TR></TABLE>
itr is not an option...don't have that much money as of now
how much did you guys get a b16 tranny for?
or
whats your setup/ what do you use your car for?? as stated before the b16 tranny is great for auto cross, but for daily driver you have to decide that one for yourself. bottom line it comes dn to personal preference. Get B16, you'll be in vtec more hahaha jk
Re: (vuse1)
I'd say GSR, I hated my B16's gearing.....you are always changing gears, and it's really annoying reving so high on the freeway. B18b gears are definately too long though.
Re: (moike)
i m going to be running an ls motor for now...but in the future i would like to swap in a vtec head to make ls/vtec. If i get the b16 tranny and run on just the ls motor for now, would that be safe b/c the ls motor isn't a high revving motor?
Thanks for all you that reply..helping alot
Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">okay you guys say that the b16 at 80 in 5th is 4000rpm what would be the gsr in 5th at 80? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moike »</TD></TR><TR><TD CLASS="quote">i like the gearing on my GSR. if you are curious about what RPM you would see on the highway :: when in 5th gear your RPM = MPH (50)
example: 80 mph in 5th = 4000 rpm </TD></TR></TABLE>
Re: (ProJectCvic)
b16 is by far the best tranny to have on any bseries setup. as for your concern with the 5th gear you can always change it to an ls final drive.
smokerz212
04-25-2006 02:04 AM
blackstar
03-08-2005 09:46 PM
