exhaust for h22 eg
exhaust for h22 eg
right now i have a skunk2 exhaust will i be able to keep it or will i have to get a custom sounds sad but this is what is keeping me from getting the swap becuase i love that exhaust
Re: exhaust for h22 eg (tonesdef)
You will most likley have a gap between where the header is and where your cat-back skunk2 exhaust begins. That gap most people either replace with a test pipe or a cat.
Re: exhaust for h22 eg (junglerunna02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 »</TD></TR><TR><TD CLASS="quote">You will most likley have a gap between where the header is and where your cat-back skunk2 exhaust begins. That gap most people either replace with a test pipe or a cat. </TD></TR></TABLE>
the problem with mine though is that the h22 downpipe doesn't come in exactly in line with the resto f the exhaust, so you can't just use a straight pipe, or expect to bolt a cat in it's place
Re: exhaust for h22 eg (Jonathan_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH »</TD></TR><TR><TD CLASS="quote">
the problem with mine though is that the h22 downpipe doesn't come in exactly in line with the resto f the exhaust, so you can't just use a straight pipe, or expect to bolt a cat in it's place</TD></TR></TABLE>
Yours was really that off?
Re: exhaust for h22 eg (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Custom 2.5" exhaust and ES oval </TD></TR></TABLE>same here.
Yours was really that off?</TD></TR></TABLE>
yeah, but I've got a Jun header...so that might contribute to it in some way.
The pipe and the header are lined up parallel, but if you extended the header straight back, it'd be about 2-3" away from the piping.
