help please.....blue wire on first gen b16 what is it
Re: help please.....blue wire on first gen b16 what is it (WCI)
Blue wire = tach wire = should be hooked up to the negative side of the ignition coil. If you have a short going from your tach to the coil (ie. an aftermarket tach or shift light that is burned out), then it won't allow your car to start.
