four wire o2 conversion...through the shock tower harness
i know this has been covered many, many times but, not to the extent of wiring it through the shock tower harness, for a factory look.
the car is a 92 civic CX with a 94 GSR conversion. i did the wiring of the knock sensor by pinning a wire to the empty slot on the CX shock tower harness that matches the GSR harness and would like to do the same for the four wire 02:
blue/red wire is the knock and the yellow/red wire is the wire i pinned in for a factory look
civic's CX subharness with new wire pinned in:
integra's engine harness, showing the knock sensor:
Re: four wire o2 conversion...through the shock tower harness (Hatch4urSnatch)
didn't we resolve the 02 wiring situation through IM ?
A recap of what we spoke of privately:
You have a 92 CX civic w/a GSR engine and you are using the GSR engine harness as well.
By factory default, all trims of the 92-95 civic (non-vtec & vtec) have the 4-wire 02 sensor wiring integrated from the ecu plug(s) out to shock tower plug, which posted images of. All integra's use a 4-wire 02 sensor as well.
So, since you're running a GSR engine harness which has the 4-wire 02 already integrated into it, you've just mated the links between the engine harness and the shocktower plug-->ecu harness and are complimenting each other's 4-wire 02 sensor connection, which = plug n' play. You don't have to wire anything up 02 (4-wire) related.
If someone plans to reuse a 92-95 CX engine harness on an engine+ecu that requires a 4-wire 02, then that person would have to add 3 more wires to complete the 4-wire 02 sensor on the engine side of the CX harness only, not to the shocktower male plug side of the harness.
Re: four wire o2 conversion...through the shock tower harness (Katman)
this was before the issue was resolved on IM. thank you though.
here's a little diagram I made today, regarding 02 & VTEC wiring...
Modified by Katman at 4:51 PM 7/14/2003
turboex
06-15-2003 08:40 AM
