need some help! 98 jdm R into 94cx wiring problem
I'm getting ready to put a 98 JDM type R into my 94 dx and I was trying to get the wire harness on and I ran into some problem. I read all over HT and everyone said to use an obd2 harness because the injector plugs, the alternator plug and the distributor plug would plug right in, so I got one from a 97 ls on ebay. The injector plugs and the alternator plug didn't fit. The injector plugs I can figure it out because the wires match up but I have problem with the alternator plug because the JDM alternator has 4 wires and the LS harness only has 3 wires and the colors don't match. But the biggest problem is that there's no plug on the harness for the Vehicle Speed Sensor(VSS) or the Throttle Possition Sensor(TPS). I looked all over the harness to see if it was cut off and it doesn't look like it was. I planed this whole week around this swap project and I cant delay it. I don't have time to get another harness for a reasonable price around here. I need to make this harness work. Should I just cut off the VSS and TPS plugs off the jdm harness and run the wires straight to the shock tower plugs.
PLEASE HELP ME OUT.
thanks in advance.
PLEASE HELP ME OUT.
thanks in advance.
Re: need some help! 98 jdm R into 94cx wiring problem (rice4life)
for the alternator, i usually take the metal shroud off the back of the alternator where the plug circuit resides. then i swap the cx onto the itr alternator.
Re: need some help! 98 jdm R into 94cx wiring problem (Fobtions)
If you cant find the vss and the tps on the teg harness then i would just take you stock one and modify it. Youve got like 3 harness' so it shouldnt be hard to make one. You know what i mean??? Just extend and modify the plugs on the stock civic harness. All with the motor out of course so you can make it look nice.
i have dicided to use my dx harness, now i just need the wire diagram to convert obd1 distributor plug to obd2. anyone has this diagram?
well, got it running saturday night and finished everything off sunday, it started up first try with no ecu code. took it around the block to see if vtec works and its working fine. the tires brake loose in 1st and 2nd gear when vtec kicks in. i was taking a frend out last night for a ride and we happens to run into a 98'ish poopstang cobra, i didnt even want to race, he was behind me and i saw him get on it, i waited until he got next to me and i droped into 3rd, i wasnt in vtec so he was pulling on me and also he had a head start, my front bumper was right behind his rear bumper when vtec kicks in, i started pulling on him then i hit 4th, when i red line 4th, i looked back and he was about a cars lenght behind me, i looked at the speedo and i'm over 100mph, so i hit the brakes and he keep going. he never slow down so i could kick his *** again.
Cap'N Chronic
04-04-2011 07:51 PM
rice4life
17
03-16-2004 03:33 PM
rice4life
12-07-2003 06:06 PM
