Need URGENT help with my h22 swap!!
alright so i dropped my motor in ( 00'h22a4) into my 92 hatch and so far the wiring has been ok and everything, but when i got to bolting my half shaft up i noticed that the bolts are different and they dont line up. Im using a 94 vtec half shaft so i thought that that was the problem but i soon realized that i had a type sh block on my hands. Since the engine is in and shifter assembly is hooked up wiring is done, theres really no way to turn back and drop my old motor in so i need help finsihing it off. Has anybody out there put a type sh engine into there civic? Im using hcp mounts and had jdmsh!t make me custom axles for the swap. Is there anyway i can finish the swap off without changing trannys or engines? I need to get the car up and running as soon as possible but the half shaft and axles are the only thing holding me back...PLEASE HELP!!!!!
Re: (Vp Special K)
Or you could try making an adapter so it would mount the imtermediate shaft properly. Try this out http://ian.clendaniel.net/gallery/noatts
hey thanks for the link, i might give that a try. could i still use the tranny that came with the engine or do i have to swap it out?
Re: (Vp Special K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vp Special K »</TD></TR><TR><TD CLASS="quote">hey thanks for the link, i might give that a try. could i still use the tranny that came with the engine or do i have to swap it out?</TD></TR></TABLE>
You talking about the ATTS trans?
Re: (racerxfear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxfear »</TD></TR><TR><TD CLASS="quote">I dont think the atts tranny would work with your swap in your 92 hatch. I think the only way to really get around this is to get a different tranny.</TD></TR></TABLE>
Yeah, I think you're gonna need a new tranny. I doubt it'll work with the ATTS.
Re: Need URGENT help with my h22 swap!! (Vp Special K)
I think I had the same problem
what I did was take the 1/2 shaft off the tran
the top left hole allmost lines up so I cut the hole open so you can bolt it on
the top right hole i didnt use
the bottom hole i made a small plate bolted to it to the 1/2 shaft , the other end i bolted to the threded hole down to the left about 1 1/2" away.
i hope this helps
95 teg w/h22 done by me !!!
i hope this helps
Re: Need URGENT help with my h22 swap!! (Integra 2.2t)
hey thanks for the help, but what i ended up doing was making my own bracket from a 1/4 thick sheet of metal, i finally got to start it up the only thing left to do is get my exhaust done and chip my ecu
gulftiresinc
12-14-2007 07:44 PM
jdm_vtec
08-30-2007 11:57 AM
freak86
10-20-2006 07:51 PM
