My swap is done: axles are torn, which replacements to buy?!??!
Okay, I want to replace my axles.... the boots are torn.... Its a JDM B16a SIR2 so i'm not sure if I can use the 94+ integra axles... because of i'm not sure if the JDM halfshaft lenght is different... Can someone clarify this for me before i start checking my parts stores. The car is a 92 hatch.
Just wanted to throw another question in here.... Since my motor is JDM motor, do I even have a Purge Cut Soldenoid.... What is that white sensor on the intake manifold runner (right side of the manifold)
Modified by EGhatched at 7:09 PM 2/28/2004
Re: My swap is done: axles are torn, which replacements to buy?!??! (EGhatched)
i just finished the same swap, yep the 94+ acura half shafts are perfect fit bro.
Re: My swap is done: axles are torn, which replacements to buy?!??! (ibemebewhobeyoube)
yeah, thats the thing.... I DONT want to change out the half shaft. I have the half shaft that came with the JDM b16a I just want to change out the axles... do i need 90-93 teg axles... or 94+
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatched »</TD></TR><TR><TD CLASS="quote">Okay, I want to replace my axles.... the boots are torn.... Its a JDM B16a SIR2 so i'm not sure if I can use the 94+ integra axles... because of i'm not sure if the JDM halfshaft lenght is different... Can someone clarify this for me before i start checking my parts stores. The car is a 92 hatch.
Modified by EGhatched at 7:09 PM 2/28/2004</TD></TR></TABLE>
Use 94 and up axels they will fit your halfshaft. You can use ls, gsr or even 99-00 Si axles. As long as they are 94 and up. Ive got ls axels in my 99-00 si because thats all Napa had in stock.
JDM knowledge
02-22-2004 07:21 AM
Si-Yaaa!
05-10-2003 05:02 PM
jdmDXrex
02-26-2002 06:48 PM
