Tranny for B20 (searched)
This may have been covered but I could not locate a thread that helped.
I am wondering which tranny is best for a b20 that is going into a del sol. I was thinking that the b16 tranny may fit the best because I could get the del sol vtec linkage that was made for the car, but I am also concerned that it is geared too high for a b20.
Thanks!
Thanks!
Re: Tranny for B20 (ek_type_r99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_type_r99 »</TD></TR><TR><TD CLASS="quote">I say any B18 tranny with LSD, I'm looking to put a LS tranny with LSD w/ my B20
........ well i think LSD works with an LS?</TD></TR></TABLE>
the OEM GSR LSD won't work for LS tranny.I wouldn't use this tranny anyways to long unless you plan on FI.GSR is a good tranny to use not to long(LS) and not to short(SI/ITR).
Re: Tranny for B20 (elevatethis)
Unless you have upgraded your bottom end, the B20 is not a good motor for running at high RPMs for and length of time. So if you do any decent amount of freeway driving, I would not recommend anything shorter than a 1994+ GSR transmission. I would stick with either a 1994+ GSR transmission or an LS transmission.
Re: Tranny for B20 (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Unless you have upgraded your bottom end, the B20 is not a good motor for running at high RPMs for and length of time.</TD></TR></TABLE>
So I'm thinking wristpins and rods should probably go in while the motor is out, right? Will that pretty much take care of that issue?
