No Map Sensor?? Wtf??
Old Feb 26, 2004 | 10:34 AM
ImprtRcr02's Avatar
Default No Map Sensor?? Wtf??
We are putting a B18a from a 93 teg into my friends 92 Civic hatch dx. Heres the problem.. his original motor had no map sensor. The engine harness off the stock 1.5 has a plug leftover around the throttle body with two wires for it. The map sensor on the B18a has a plug in for 3 wires. Is there a way these two connect somehow? If not then how do we hook this map sensor up? Thanks for help.
ImprtRcr02
Old Feb 26, 2004 | 12:49 PM
v4lu3s's Avatar
RTFM
the 2 wires isprobably for the idle control valve.
Old Feb 26, 2004 | 06:34 PM
Maintenance's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the 2 wires is probably for the idle control valve.</TD></TR></TABLE>
yeah its probably the IAC valve. Or tell us what the colors are to the wires. I just finished a 92 ls b18a swap into my frinend's 92 civic dx three days ago. And the map sensor should be 3 wires if your using the dx wiring harness. All you have to do is get the map sensor and run a vacuum hose from the map to the nipple on the throttle body. And that should be it.
Slacker93eg
Sep 12, 2012 09:48 AM
JDM-JAMES
Jul 20, 2008 01:36 PM
0ldsk00lef
Aug 22, 2007 08:55 PM
blackeg
May 11, 2007 07:20 PM
ImprtRcr02
Feb 26, 2004 01:43 PM
