H22 Civic running.
H22 Civic running.
Hey guys, sorry to be so untechnical but I know this is the forum that these guys hang out in and I wanted to send a thanks to them.
Thank you poison, jason kidd, junglerunna, and h22ek for all the help and advice you guys gave to a humble ricer. The H22 FAQ at the top of the forum was the only reason I decided to go ahead with the swap. I value the reliability of my honda and those posts lay out almost everything you need to know about the swap.
Special thanks to Kenny and his gay friend.
Without you letting josh and i sit around and waste a day of swapping so you could wiring up my harness (correctly on the first try I might add) I would've never got this thing done; moreover, i hope to make you weep for joy at the track this Friday (if the correct shifter cables come in by then ).
Some of the other forums the moderators get super elitist and flame you for everything, you guys all have great attitudes toward us n00bs and I'd like to thank the hell out of all of you.
Re: H22 Civic running. (DarkKnight[DMD])
That is what its all about.. Just drive de b!tch and work your way until you are finally satisfied with the results.. Like I sad before swapping it in is always the easiest part.. :0
Re: H22 Civic running. (Jason kiDD)
I second that thank you. Between poison, jason, and newman, i dont know what i would have done without you guys. Heh, thanks a ton fellas!!!
4g4me
05-14-2002 08:52 AM
