Wiring Question ?
Old Mar 2, 2004 | 01:39 PM
89sib16's Avatar
Default Wiring Question ?
i am wiring a b16a into an 89 crx si doe's the wire A8 get cut and rewired into the v-tech selinoid or do i splice this wireinto A8 AND NOT CUT FROM HARNESS basically just need to know if i keep this wire hooked into ecu and splcie into the new wire ran from the v-tech selinoid or cut a8 wire in the harness and tie into new wire ran from selinoid
Old Mar 3, 2004 | 02:20 AM
Fobtions's Avatar
Default Re: Wiring Question ? (89sib16)
i dont think anyhting is at A8 to begin with, u need to cut anything at a8 or add a wire and run it to the solenoid.
Old Mar 3, 2004 | 02:29 AM
tiresmoke's Avatar
you need to make sure that the wire coming from pin out A8 is run to your Vtec Solenoid. A8 pin out maybe emplty so add a wire if it isn't cut the wire and add onto it.
Old Mar 3, 2004 | 02:34 AM
Fobtions's Avatar
Default Re: Wiring Question ? (tiresmoke)
thats what i said
TheWhitten
South
Nov 11, 2015 02:00 PM
that-guy
Engine Management and Tuning
Nov 29, 2010 04:45 PM
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
D16Z6racing
Mar 21, 2007 05:56 AM
streetstylenperformance
Feb 26, 2004 03:28 PM
