will h22 JRSC fit h23???
Re: will h22 JRSC fit h23??? (4drHseriesEGII)
I remember that i contacted JR along time ago and asked the same question. But if i remember correctly, the heads are different, so it WON'T fit. And they aren't coming out with a H23 SC....which made me . hahaha, but i may be wrong..but i think i'm 90% right
Re: will h22 JRSC fit h23??? (B18CUL8R)
Here are the problems; the supercharger bolts up to the lower half of the intake manifold. The H22 and H23 lower halves of the intake manifolds are different. The top halves are the same so the bolt patterns are the same where the supercharger bolts to the intake manifold. So that probably fits.
But as you can see by the accompanying image, there is a pulley system that bolts to the powersteering bracket. The powersteering bracket for the H23 and H22 models are different. The difference may or may not be significant. My best guess is that the JRSC is usuable with some modifications. Modifications will void the warranty and are probably not a good idea.
brian g
brian g
Greyout
06-12-2003 09:05 AM
