Doing Tbelt on JDM B16a,,,, need some info...
The car is getting a new tensioner, waterpump, tbelt, etc...
I have a JDM b16a motor. Would the parts from a 99-00 SIR work? Or should I get them from the Del Sol VTEC? (If so which year del sol is that)?
Thanks in advance!
Thanks in advance!
Re: Doing Tbelt on JDM B16a,,,, need some info... (Got Spoool)
get all of the parts oem because sometimes at place like napa and autozone you will get parts for a D16 and it is a major hassel, some of my friends have tried to save money and then get skrewed on the belt
If i remember correct. I had to get a Delsol belt and pump....something was wrong with the SI. I have a 1st gen B16
Re: Doing Tbelt on JDM B16a,,,, need some info... (TurboB16aEG)
Just did a tbelt and water pump in my JDM 16a second gen. I ordered my parts for a USDM 95 delsol dohc vtec Not sure about 99-00 si parts. I wouldnt chance it. Try to get oem honda also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG »</TD></TR><TR><TD CLASS="quote">If i remember correct. I had to get a Delsol belt and pump....something was wrong with the SI. I have a 1st gen B16</TD></TR></TABLE>
They are identical parts. No reason anything should be wrong with the Si timing belt assuming you were given the right part.
Re: Doing Tbelt on JDM B16a,,,, need some info... (Hybrid93Eg)
Apparently everything works fine... Im going to pick up the car tomorrow.
z6hatchboy
08-06-2008 03:59 PM
ApolloSpeed
08-19-2005 01:59 PM
