Low idle problem!
Old Mar 2, 2004 | 06:33 PM
hodsintegra23's Avatar
Default Low idle problem!
My problem is that my idle is dropping really low and the car shakes from it when I put it in nuetral.
What could be causing this?
Old Mar 2, 2004 | 06:35 PM
Default Re: Low idle problem! (hodsintegra23)
When I stop at a stop sign or something it falls really low like under 400 and then bounces up again. It does this for a while, but I used to turn on my vent at like 3 level and it would idle out fine again but now it just bounces really low and back up again.
Old Mar 2, 2004 | 08:16 PM
krazie1's Avatar
BANNED
yeah it will do that cuz u are requiring more power
i would try to turn ur idle up a bit
know wherre that is at???
Old Mar 3, 2004 | 01:26 PM
Yeah I'm gonna turn it up a little today.
I think I just need to check a bunch of things to find the problem.
Old Mar 3, 2004 | 01:43 PM
Turbogixxer's Avatar
Does it idle smooth? you may have a vacuum leak.
Old Mar 3, 2004 | 04:04 PM
b16vtecsol's Avatar
Default Re: Low idle problem! (turbogixxer)
i'm having this same problem, only does it once in a while though
Old Mar 3, 2004 | 07:27 PM
Default Re: Low idle problem! (b16vtecsol)
it does idle smooth i guess it just bounces low when i brake or put it in neutral.
Old Mar 3, 2004 | 07:28 PM
what type of swap you got, what car?
Old Mar 4, 2004 | 07:33 PM
it's a 95 integra with h22 swap.
Old Mar 5, 2004 | 12:31 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Does it idle smooth? you may have a vacuum leak.</TD></TR></TABLE>
Werd
Old Mar 7, 2004 | 07:50 PM
Default Re: Low idle problem! (DarkKnight[DMD])
when i turn the heat or vent on it stops bouncing and stays at a normal idle.
What does that mean?
Old Mar 12, 2004 | 03:19 PM
who-got-rice's Avatar
check your grounds
hell0curry
Apr 4, 2012 11:20 PM
jdm4drSi
Apr 6, 2007 08:19 AM
ic89
Oct 16, 2006 05:38 PM
ExAcc
Sep 20, 2005 10:49 AM
