90'ls b18b to 95'gsr
Re: 90'ls b18b to 95'gsr (integ.s.ra)
http://www.g2ic.com --> Teg Tips --> Engine Section --> Engine Swap Guide
Should give you all you need to know about swapping vtec engines into 90-93 integras.
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ.s.ra »</TD></TR><TR><TD CLASS="quote">what will i need to ensure that this swap is a successful one?? (ecu/tranny/axles... etc..) thanks for yall help/insight.</TD></TR></TABLE>
94-01 axles
90-91 engine harness
hasport shift linkage
hasport mounts
95 gsr motor/trans
90-91 dist
skunk 2 jumper harness
or the cheap way and use a b17 trans!
94-01 axles
hasport mounts
95 gsr motor/trans
90-91 dist
Hatch It
05-12-2004 06:23 AM
