B16a Wont crank/turm over after swap.
Here are the details.
91 civic Dx hatch
b16a sir II
Obd 0 PR3 ecu
i dont have any o2 sensors hooked up yet getting code 1 on my ecu which is primary o2.
the car was sitting for a while so im going to drain the old fuel and add new fuel...
any suggestions...
I think every thing is grounded correctly and i smell fuel so what could be wrong?
Modified by paybac4223 at 10:59 AM 2/24/2004
91 civic Dx hatch
b16a sir II
Obd 0 PR3 ecu
any suggestions...
Re: B16a Wont crank/turm over after swap. (paybac4223)
First off.
I would check the starter ground, starter power and battery charge.
Is it not even attempting to crank?
Re: B16a Wont crank/turm over after swap. (saleensolution)
well i was just looking at a pic of a ZC in a 4th gen hatch like mine, i noticed that he has a ground on the timing belt cover which goes to the valve cover; which then goes to the ground on the radiator housing. In contrast my ground only goes from the valve cover to the radiator ground.... maybe i'll add the other ground also...
