What sensor is This
Old Mar 1, 2004 | 07:28 PM
.Hookedonhatch.'s Avatar
Default What sensor is This
Ok first off for all the haters, i searched like a pirate and couldnt find **** that pertained to my question.
Ok is this the map sensor, if so why is there a sensor that says the same thing as this one on top of the throttle body. They both say sensor assy. map. I am using a vx engine harness and i have a plug plugged into the throttle body sensor, but there are no plugs left that will fit into this sensor in the pic. What should i plug into it. ?????? it is a jdm B18c. Thanks
Old Mar 1, 2004 | 10:08 PM
gamakichi77's Avatar
Default Re: What sensor is This (Hookedonhatch)
yep.....thats is definitely a MAP Sensor....nothing than that....
Old Mar 2, 2004 | 11:23 AM
doublejz's Avatar
Default Re: What sensor is This (acidburns_di)
im pretty sure the sticker even says map on it
Old Mar 2, 2004 | 01:09 PM
2trix's Avatar
Default Re: What sensor is This (doublejz)
first of all that is a map sensor...yahoo...secondly: every once in a while you see a diff ***....some maps just hook to vacuum hose and mount to the firewall...some attach directly to the TB...just hook up the one on the TB and remove the other...if theres a left over vacuum line, pull it and cap off the nipple...
Old Mar 2, 2004 | 01:11 PM
Default Re: What sensor is This (2trix)
thanks man that helps a **** load. Thanks again
Old Mar 2, 2004 | 09:19 PM
Can anyone confirm that this will not make the car throw a code or run in limp *** mode
Old Mar 2, 2004 | 09:34 PM
Maintenance's Avatar
If you already have a map sensor mounted on your throttle body then you dont need the second one in the pic. If the one in the pic has a vacuum line comming from the intake manifold. Then just cap it off. Sometimes they are external like the one you have and sometimes its mounted on the throttle body. You only need one map sensor. Just unplug the one in the pic and save it for a spare part. So your good to go.
'90crxSI
May 23, 2006 06:53 AM
SVOboy
Mar 26, 2006 11:48 AM
civichatch67
Sep 21, 2005 10:11 AM
.Hookedonhatch.
Mar 3, 2004 05:46 AM
comptechgsr2000
May 8, 2002 03:53 PM
