Wiring question on 95 vx to jdm d15b?
I am going to be swapping a d15b jdm into my hatch vx with the vtec-e engine. When i plug in my stock harness will all the sensors pull right in the that motor or will there be some to splice or some that wont plug in? I am also going to use a p28 ecu.. Is that right? So if there is anything you guys can post back to help out please do so..
Thanks
Thanks
Re: Wiring question on 95 vx to jdm d15b? (vxhatch02)
every thing should plug in, you read the article i posted that is about all I know about this swap. the purge control solenoid should be your only mystery as the D15B has the tab to mount it but it needs to be drilled and tapped. and there is no vacuum tube out the back of the intake manifold to put the vacuum line. But you should beable to T into any vacuum line the pressure shold be the same. OR I'm not sure about this If you run into trouble when you get it complete and the purge control solenoid is giving you a hard time maybe you can swap out the whole intake manifold. but I'm unsure. I think it should work. I also don't know about the O2 sensor if you use your manifold, down pipe and O2 sensor it should just be plug and play because you used your Vx harness. just my $.02
dfoxengr
07-28-2008 10:35 AM
someforlight
03-26-2005 06:11 PM
McNizzle
12
01-12-2005 02:50 PM
