Shift Linkage?
It's not that it won't work, they are the same as far as the way they operate it's just their design. The 90-93 DA Integra linkage will only work with those model years or it can be modded to fit the EF Civic/CRX with a B swap. You need to get a 94-01 Integra (any model) or JDM EG Civic linkage.
The DA 90-93 shift linkage will work just fine in you 92-95 civic. The difference between the 90-93 and 94-00 Integra linkage is the thickness otherwise they fit and just the same. I did it plenty of times
civcxhatch
Feb 20, 2005 08:24 PM
