Got my h22 today from hmo. What else do I need?
Got my h22a from hmo today. I got the whole change over, with HAsport mounts, HAsport axles. I also purchased a flexalite fan and ecu jumper. My car is a 99 civic hatch and my motor is obd1. What other parts am I missing? My friends have done several b series swaps but no h series. Thanks alot for any info
yep, the complete change over came with the resistor box and the shift linkage. Thing is all of my friends swaps were 0b1 chassis with obd1 motors. What all has to be done to the resistor box? Also can anyone help me with where to find instructions on the harness? I going to jump it to the obd1 ecu.
Re: (KNIVES)
H-series swap info
https://honda-tech.com/zerothread?id=650329
general swap info
https://honda-tech.com/zerothread?id=650230
FYI, i used my stock harness off my EK and added plugs from the prelude...pretty simple, very tedious work though...did you get your radiator hoses? i used prelude ones cut to fit. what axles you using?
general swap info
Re: (breakaway)
HAsport axles. Trying to get all the info by the end of the week so I can start on the swap. The HAsport axles let you use the prelude intermediate shaft.
Re: (KNIVES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KNIVES »</TD></TR><TR><TD CLASS="quote">What all has to be done to the resistor box?.</TD></TR></TABLE>
Your connector for a EK will be under the Intake Manifold (of the stock motor). It is a grey connector (there should be a blue one too). The second row down of the connector (four wires a cross) are for your injectors. Just do the same as EG people do and you are set.
Re: Got my h22 today from hmo. What else do I need? (KNIVES)
There's a 100 little items you will need along the way. There's really no way to explain it all to you.
You'll need misc bolts for just about everything, the shift linkage clips for the shift linkage....
You'll see.
You'll see.
061000rr
09-29-2010 07:39 AM
spraymysol
12-08-2008 02:48 PM
Bigjussin
02-17-2004 06:52 PM
