GSR Swap Questions (searched)
Before I get flamed...Yes, I did search, and did not come up with anything that helped me.
I need info on exactly what needs to be done in order to drop a 99 B18C1 into a 95 Integra GS-R. Wireing, mounts, I need it all. Pics would be great, too. Thanks in advance.
Re: GSR Swap Questions (lax1185)
Reuse your stock mounts. The harness will plug right in (OBD2 harness to a OBD1 car). Run your OBD1 ECU and you are set. IT is a easy swap.
You can simply install the complete 99 B18C1 longblock with the 99 engine harness then simply use a 94-95 P72 ECU. The mounts from both year motors (95 and 99) are the same so if the 99 comes with mounts just use those.
Even though this swap is going into a Civic, it's a very good swap article that should be helpful:
B18C1 into EG Install
ballplayer
17
05-11-2005 03:45 AM
THugluv423
03-14-2005 09:25 PM
