throdobody tps sensor
Old Mar 4, 2004 | 06:48 PM
jdm_gsr's Avatar
Default throdobody tps sensor
my car idols like crap rpm goes up and down from 1000 to 2000 sometime even stay at 3000 is that cause of the tps sensor. if so i have a Ls throdbody and can i change the tps from the Ls to my GSR the one that has problems or is there something else besides the tps sensor
Old Mar 5, 2004 | 05:02 AM
VTECVillain's Avatar
Default Re: throdobody tps sensor (jdm_gsr)
First it's called a throttle body If your idle is fluctuating, first check for vacuum leaks then clean your IACV. The TPS can go bad but chances are your problem is elsewhere. If it does turn out to be the TPS, yes you can use one from the LS on your GSR throttle body.
Old Mar 5, 2004 | 11:49 AM
jdm_gsr's Avatar
first of all thanks for corectin me and i checked alreqady for vacuum leaks and what is the iacv where is it located at
Old Mar 5, 2004 | 08:50 PM
Combustion Contraption's Avatar
on the back of the intake manifold.
unix4linux
Apr 4, 2011 12:07 PM
crfr230
Apr 24, 2007 07:48 PM
nutball72
Nov 11, 2006 07:14 PM
dc4_wHORE
Sep 26, 2006 04:34 PM
