Not revving past 4700 RPM
I have a 97 EK with gsr swap and it's not letting me rev pass about 47000rpm.
It kicks it back down and feels like there's a rev limiter on it.
Any advice?
Any advice?
Re: Not revving past 4700 RPM (kitchale)
okay I just checked the VSS, it's hooked up, but how do I check if it's good or not.
I remember when I did the swap, coolant got in where the sensor where you plug it in.
it could also be your distributor...i remember when my cousins b17 distributor went bad he couldnt rev it past 4000rpm.
if you're getting a 22 CEL, try testing that sensor or if you have another VTEC solenoid replace it and see if that works
Re: Not revving past 4700 RPM (93H22ACX)
if you have any friends with vtec cars, see if you could borrow it off one of their cars to see if that is the problem. They are know to be faulty, but you should still be able to rev the car past 4700 rpms on the non-vtec lobes
