Cat question??
Old Jul 27, 2004 | 04:59 PM
JoseCuervo's Avatar
Default Cat question??
Thanks for taking the time to look into this thread!
-I recently completed an LS swap on a '96 H/B. When done, I took the car to a muffler shop to install the cat. Said stock cat was given to me by a friend who had it in his '99 EX (turbo), so that cat was probably on its last leg. To my understanding, the EX, SI, LS cats were the same. I wanted it for measuring purposes since I didn't want to weld the cat in place; I wanted to be able to remove it if needed. Now that the swap is done, I don't want to hurt the car by running that cat any longer. Here's my question, what would be a good replacement, bolt on cat? All suggestions will be appreciated. Thanks!
Old Jul 27, 2004 | 08:10 PM
milo's Avatar
Default Re: Cat question?? (JoseCuervo)
you can IM "smsp" on here or call ipsracing.com. you probably need to measure the distance from flange A (header end)to flange B (b pipe) for an exact fit.
Old Jul 28, 2004 | 02:05 AM
JoseCuervo's Avatar
Default Re: Cat question?? (milo)
Thanks for the info.
easyFOsheezy
Aug 26, 2010 02:03 PM
Karizmah
Mar 18, 2006 08:58 PM
PresSI
11
Feb 8, 2002 05:50 AM
smoothludey2
Jan 16, 2002 11:50 AM
