Zdyne One wire ECU
Zdyne One wire ECU
As the title states this is a question about my Zdyne ecu.
I have a 1989 si hatch *see sig*
installing a jdm sirII with obd0 dist / injectors / harness and ecu
The saddest thing is. I looked around the net to see how to install this thing (ecu)... and in all the pages i've read and looked at... none say which "one wire" i need to run....
So If anyone knows it would be great
I do of course have the second 02 sensor that is not hooked up right now... I'm wondering if that is the one.
It's stated that the ecu has the vtec solonoid oil pressure all controlled within.
so I need some advice.
Re: Zdyne One wire ECU (89s1)
used ur si engine wiring harness and add 1 wire for vtec thru the ecu.non obd zdyne wilkl plug in w/o modification.i hope this will help u.
later
honda connection
5511 mission st.sf,ca
4155871079
later
honda connection
4155871079
if you have the one wire run a wire from the vtec switch to the ecu to pin A8 on the white ecu plug. make sure you use the right guage wire also. good program for a stock B16 with mild mods
Re: Zdyne One wire ECU (smart monkey)
the white ecu plug.... on the harness under hood? or on the actual ECU clip?
and by vtec switch i'm asuming that would be the green connector coming off the vtec solonoid?
thanks BTW
thanks BTW
tekstyle
02-27-2008 12:15 PM
greebler
05-12-2003 10:53 AM
LshatchTurbo
10-13-2001 05:16 PM
