Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes?
B A N N E D
i'm thinking about doing a rear disk brake swap on a 92-95 civic in favor of the 90-93 teg brakes. now, i've been told that as long as i use the brake booster, master cylinder, brake lines, and e-brake cable from the teg, it will bolt up to the 92-95 civic. if i have been told wrong, please let me know.
my other question is this, will the 92-95 civic drum setup all fit back on the teg(so the car can roll and not sit on jack stands)? if anyone has done this before or know of anyone that has, let me know. thanks!
Re: Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes? (vtecb20coupe)
hey, vtecb20coupe. this is megotvtec. one of my stupid drunk friends was on my computer last night on honda-tech, and one of the mods pm'd him telling him he couldnt have the name honda-tech as a username, and he wrote back telling the mod to stfu and was talking **** or something.
anyway, the mod got his username and MY username banned!
so this is my new username and i can't pm for a while, so untill i can pm, please just write to me useing this thread. thanks!
let me know how the shipping is going.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe »</TD></TR><TR><TD CLASS="quote">i'm thinking about doing a rear disk brake swap on a 92-95 civic in favor of the 90-93 teg brakes. now, i've been told that as long as i use the brake booster, master cylinder, brake lines, and e-brake cable from the teg, it will bolt up to the 92-95 civic. if i have been told wrong, please let me know.
my other question is this, will the 92-95 civic drum setup all fit back on the teg(so the car can roll and not sit on jack stands)? if anyone has done this before or know of anyone that has, let me know. thanks!</TD></TR></TABLE>
yes, 90-93 integra (DA) rear teg brakes will fit on a 92-95 civic, but you will need to reuse the 92-95 civic's compensator arms and rear LCA arms. Everything else, rear trailing arm related should bolt right up. You CAN use the 92-95 rear drums w/trailing arms on the DA integra, just make sure you reuse the integra's compensator arms and rear LCA's on them.
You can also use the DA MC/booster too if you wish. I can't recall if you'll need to modify the hardlines at all or not.
The front DA brakes (knuckle & hub assembly) will NOT bolt up to a 92-95 civic....sorry.
Question...Are 86-89 rear brakes the same as 90-93 rear brakes, or no?
Re: Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes? (K@man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K@man »</TD></TR><TR><TD CLASS="quote">
The front DA brakes (knuckle & hub assembly) will NOT bolt up to a 92-95 civic....sorry.</TD></TR></TABLE>
I took the whole thing off the Integra and bolted it up to my EG with no problems. Why do you say that you have to reuse the compensator arms and lower control arms?
vtecb20coupe
08-03-2004 11:17 AM
WHATS VTEC
12-30-2002 04:34 PM
