need some help with wiring
Old Jul 27, 2004 | 06:29 AM
AllMoToRB18c's Avatar
Default need some help with wiring
i have a 96 auto integra....i just made it 5-speed and i put a 98 b18c wit an obd1 engine harness.....so now here my problem....the obd2 ecu reads the crank position sensor but theres no clip for it on the obd1 engine harness....so i ran the clip straight to the ecu....but the pins i was told to run it to dont work and i still get check engine for it....so i need to know which pins to run it to....its a 2 wire clip ...one blue wire and one white wire....if u can show me a detailed diagram that will be great...thanks
Old Jul 28, 2004 | 05:21 AM
IntegraB18's Avatar
Default Re: need some help with wiring (AllMoToRB18c)
bump
Old Jul 29, 2004 | 05:06 AM
IntegraB18's Avatar
Default Re: need some help with wiring (IntegraB18)
no help guys?
Old Aug 10, 2004 | 04:56 AM
IntegraB18's Avatar
i need help...PLEASE!!!
Old Aug 10, 2004 | 08:39 AM
IntegraB18's Avatar
ttt
Old Aug 10, 2004 | 11:47 AM
IntegraB18's Avatar
bump
Old Aug 10, 2004 | 02:08 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
why dont you put the obd2 harness back in? ... just a thought
Old Aug 10, 2004 | 02:39 PM
IntegraB18's Avatar
Default Re: need some help with wiring (HOOKUPS)
i dont have an obd2 harness...well i have the LS harness but i have and obd1 dizzy and alt. and injector so i gotta do a lot of wiring that i dont feel like doin...id rather wire up the sensor
Old Sep 13, 2004 | 08:33 AM
BLUE EH3's Avatar
Help we my pennies
is the car white?
Old Sep 13, 2004 | 08:34 AM
BLUE EH3's Avatar
Help we my pennies
bump
Old Sep 13, 2004 | 02:02 PM
Slopoke's Avatar
Default Re: need some help with wiring (BLUE EH3)
I would personally just get a jumper harness and an obd1 ecu.
That would solve your problems.
Did you actually check to see what codes its throwing?
Do you have both o2 sensors wired up. If not, that will throw a code.
Old Sep 13, 2004 | 02:35 PM
Cnote's Avatar
Default Re: need some help with wiring (Slopoke)
the pin you are adding needs to be spliced into the Dizzy as well. If you have the manual you'll notice it's part of the measuring.
Old Sep 15, 2004 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">is the car white?</TD></TR></TABLE>
yea its white....will i know u know who i am...stop acting stupid
thanks for the input guys but i got it wired up with out wiring it to the dizzy...the post is like a month old...just BLUE EH3 keeps bringin up my old post for no reason what so ever
Feb 15, 2008 08:56 AM
777
Feb 14, 2008 08:44 AM
hatch96y7
Jun 19, 2007 03:26 PM
