best way to run a d16z6 obd0?
Guys I did a d16z6 swap on my a crx like 3 months ago, i know the car is running very poor because of the pm6 computer so I was wondering if there is something else to run this swap a little bit better.
Ive heard of people running pg7 ecus and stuff like that, what would be a good option?
I was also thinking of using turbo edit on a pr3 with p28 maps.
Anyways, I just want to listen to some options and experiences.
Re: best way to run a d16z6 obd0? (iNetForce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNetForce »</TD></TR><TR><TD CLASS="quote">is it just an idea the thing with the p28 ecu or u really know how to do it?</TD></TR></TABLE>
You can also get an obd0-obd1 jumper harness and run a regular P28 as well.
Re: best way to run a d16z6 obd0? (poison)
I know, is not that i just want to know more options, im going obd1 for sure, but i wanted to know the options and also if people noticed a difference going from a pm6 to a pg7 and stuff like that.
you can either conver to obd1 or I use the zdyne 1 wire with the sohc vtec program and notch the stock si dist to mount to the head.
Ride1226
05-15-2012 04:54 PM
halfpint
07-20-2003 07:47 AM
