Budget Swap
Old Aug 2, 2004 | 06:55 AM
DailyBlown's Avatar
Default Budget Swap
I search and couldn't find any information on this topic, but I am sure someone has done this swap before...My friend and I are swapping a GS-R motor into a LS integra. Everything bolted up properly and is hooked up. The only problem we are running into is the car's wire harness has a extra plug but the motor doesn't and we aren't really sure what the extra plug is....vtec? If anyone knows please helps out with links, etc hook it up correctly. Thanks in advance
Old Aug 3, 2004 | 06:58 AM
DailyBlown's Avatar
Default Re: Budget Swap (DailyBlown)
bump
Old Aug 3, 2004 | 01:54 PM
DailyBlown's Avatar
no one has ever swapped a gs-r motor into a ls chassis??!!
it is a gray plug with 2 wires (1) red wire and (2) yellow w/ black strip
Modified by DailyBlown at 3:05 PM 8/3/2004
Old Aug 3, 2004 | 03:21 PM
Adam.'s Avatar
well, does the engine run properly?
Old Aug 3, 2004 | 04:53 PM
DailyBlown's Avatar
Default Re: Budget Swap (DarkKnight[DMD])
it wont start
Old Aug 4, 2004 | 04:51 AM
civicjester's Avatar
do you have a pic or describe where the plug is located (front, back, right ,left, top , bottom)
Old Aug 4, 2004 | 10:03 AM
Adam.'s Avatar
Are you sure it isn't your thermostat ground?
Old Aug 4, 2004 | 10:28 AM
Turbogixxer's Avatar
What year is the harness? Where is the plug in the harness? (aka: by timing belt, by starter, etc.)
Old Aug 5, 2004 | 05:23 PM
RuskeR's Avatar
DL an FSM for the year integra you got the motor from. Then you can figure out what plug your looking for.
Old Aug 9, 2004 | 01:03 PM
DailyBlown's Avatar
Default Re: (RuskeR)
The harness I believe is a '95 and it is located near the battery (see pic) thanks
Old Aug 9, 2004 | 08:31 PM
krzyaccord's Avatar
Default Re: (DailyBlown)
It might be a plug that has to do with the dizzy, I think the black/yellow wire is for the power to the coil. Does it have spark? Just my 0.2cent!
Alex V
Jul 5, 2019 10:46 AM
belex202
Acura TL, RL & ZDX
Dec 9, 2009 11:28 AM
HondaLove517
Nov 21, 2008 06:09 PM
Boofster
Jan 27, 2004 07:49 PM
