H22a into 99 Dc2...I Got Wiring PRoblems! HELP!
SO here's the problem...I got a 99 H22a that im putting in a 99 Dc2 GsR. The motor was previously in a 99 hb. The harness on the motor is made for the Hb. I was wonderin what all i have to do to be able to drop in the dc2. I will be running a chipped P28 ecu. Is there any way i can splice the the harness on the motor into a obd-2 gsr harness?? any help will be appreciated. thanks
Re: H22a into 99 Dc2...I Got Wiring PRoblems! HELP! (99R-type)
u need to take the harness off the motor, and use it for spare wires/connections.
u make ur own harness. use the integra harness and fit it to ur engine.
Superdragr45
04-27-2005 09:28 PM
